问题如图,怎么计算正确率
求(answer_state=0的总数)/(answer_state的全部总数)
yzm681560 发布于 2021-10-29 15:34 (编辑于 2021-10-29 15:34)
七夜Lv6初级互助
发布于2021-10-30 22:45
select sum(case when answer_state = 0 then 1 else 0 end)/count(answer_state) from (这里嵌套你的子查询就行)
jy804909Lv4见习互助
发布于2021-10-29 15:39(编辑于 2021-10-29 15:40)
select convert(decimal(18, 2),
(select count(*) from XXX where answer_state=0)
NULLIF(convert(decimal(18, 2),
(select count(*) from XXX )
yzm339714Lv6中级互助
发布于2021-11-3 11:36(编辑于 2021-11-3 11:36)
select (sum(case when answer_state = 0 then 1 else 0 end)/count(1))as ZhengQueLv from  表
  • 514浏览人数
  • 最后回答于:2021-11-3 11:36
