HEBING字段为空的时候id01字段的数在前面字段里,HEBING字段是两位时,出现在前面和中间
SELECT  ID01, HEBING,  SUBSTR(case when hebing is null then SUBSTR(HEBING,1,INSTR(HEBING,'''')-1)  else HEBING end ) as 前面,   replace(SUBSTR(HEBING,INSTR(HEBING,',')+1, (INSTR(HEBING,',',1,2)-INSTR(HEBING,',')-1)),chr(39),'') as 中间 ,    replace(SUBSTR(HEBING,INSTR(HEBING,',',1,2)+1) ,chr(39),'') as 最后  from QRQC_TRACK_REPORT FOR UPDATE 这条语句是后来修改了一下的语句  但还是不对 报图2的错
SELECT  ID01, HEBING,  SUBSTR(HEBING,1,INSTR(HEBING,'''')-1) as 前面,   replace(SUBSTR(HEBING,INSTR(HEBING,',')+1, (INSTR(HEBING,',',1,2)-INSTR(HEBING,',')-1)),chr(39),'') as 中间 ,    replace(SUBSTR(HEBING,INSTR(HEBING,',',1,2)+1) ,chr(39),'') as 最后  from QRQC_TRACK_REPORT FOR UPDATE
用户DZNws0326467 发布于 2022-2-21 09:52 (编辑于 2022-2-21 09:56)
发布于2022-2-21 10:03(编辑于 2022-7-23 17:22)
SELECT
id01,
HEBING,
case when t.HEBING is null then id01 else  SUBSTR(HEBING,1,INSTR(t.HEBING,'''')-1)  end as 前面,
trim(replace(substr(replace(HEBING,',',lpad(' ',40,' ')) ,15,35),chr(39),''))  as 中间,
trim(replace(substr(replace(HEBING,',',lpad(' ',40,' ')) ,70,35),chr(39),''))  as 最后
---------------------重新补充答案2022-07-23,以前没有写的语句由于没有模拟数据没有做测试现在重新模拟数据做测试参考如下,你报错的语句是oracel,那么oracel的语句参考如下----------------------
模拟的数据类似如下和你图片一样:
最后生成的语句
SELECT
id01,
HEBING,
case when t.HEBING is null then to_char(id01)
when INSTR(t.HEBING,'''')=0 then t.HEBING else  SUBSTR(HEBING,1,INSTR(t.HEBING,'''')-1)  end as 前面,
from (
select 1 as id01,'5'||''','''||4 as HEBING from dual
union all
select 2 as id01,null as HEBING from dual
union all
select 3 as id01,'5'||''','''||4||''''||','||'6' as HEBING from dual
union all
select 4 as id01,'6' as HEBING from dual
) t
  • 346浏览人数
  • 最后回答于:2022-7-23 17:22
