补,问:这个SQL如何编写?
FineReport 学习2 发布于 2022-2-22 20:28
发布于2022-2-22 21:17
SELECT
 rkfs,
sum(case when ck ="DFW" then piece else 0 end) as piece,
sum(case when ck ="DFW" then cmb else 0 end) as cmb,
sum(case when ck ="PHX" then piece else 0 end) as piece1,
sum(case when ck ="PHX" then cmb else 0 end) as cmb1
FROM
 test
GROUP BY
 rkfs
union all
SELECT
 hj as rkfs,
FROM
 test
发布于2022-2-22 20:50
你最终要什么效果?没有明白。好待也说一下要的结果呀。
GnefnujnusLv6资深互助
发布于2022-2-22 21:06
  • 351浏览人数
  • 最后回答于:2022-2-22 21:17
