帮忙改一下SQLSERVER的sql语句
select c.ITEM
       from (select *
             from dbo.活动区间ITEM a
             where convert(varchar(10), time, 120) >= '${p3}'
               and convert(varchar(10), time, 120) <= '${p4}'
               and a.ITEM not in (select ITEM
                              from dbo.活动区间ITEM
                              where convert(varchar(10), time, 120) >= '${p1}'
                                and convert(varchar(10), time, 120) <= '${p2}'${if(p5="全部","",if(p5="其他","and left(ITEM,2) NOT IN ('AA' ,'AB', 'AC' ,'AD','AE')","and left(ITEM,2)='"+p5+"'"))})${if(p5="全部","",if(p5="其他","and left(ITEM,2) NOT IN ('AA' ,'AB', 'AC' ,'AD','AE')","and left(ITEM,2)='"+p5+"'"))}
${if(SQE="全部","","and SQE ='"+SQE+"'")}) c
       group by c.ITEM
我数据库里面还有供应商和SQE和TIME三列 我怎么同时查出来
callie 发布于 2022-4-28 17:25
巴拉巴拉1234Lv6初级互助
发布于2022-4-28 17:35
select c.ITEM
,`供应商`
,`SQE`
,TIME
       from (select *
             from dbo.活动区间ITEM a
                              from dbo.活动区间ITEM
       group by c.ITEM
发布于2022-4-28 17:31
你把三列字段放在你的sql里面展示出来就行了呀。。。
  • callie callie(提问者) 一开始的那个我需要用他来去除重复项
    2022-04-28 17:34
  • 352浏览人数
  • 最后回答于:2022-4-28 17:35
