如下Sql,这个if是有什么问题吗,两个判断的sql一样只是查询条件不一样
每次不管判断条件是什么只有第一个判断的数据是正确的,后面都是错误
${if(ywType="1.71","
select area_name,sarea_name,market,ccusheadcode,ccusname,cusattribute,ccusperson,sum(今年值) as 今年值,sum(去年值) as 去年值,sum(前年值) as 前年值,nameStr
from (
select a.area_name,a.sarea_name,b.market,c.ccusheadcode,d.ccusname,d.cusAttribute,d.ccusperson,SUM(ISNULL(c.inatsum_bi,0)-isnull(c.thinatsum_bi,0))*b.prop_ywy AS 今年值,0 去年值,0 前年值,
 CASE a.area_name WHEN '赛蒙渠道' THEN '赛蒙' ELSE '明月' END AS nameStr
 from BI_sale_area_part a
 left join BI_cus_ywy b on a.market=b.market
 left join BI_sale_cinvcode_day c on b.ccusheadcode=c.ccusheadcode
 LEFT JOIN (select  distinct ccusheadcode ,ccusname,ccusperson,cusAttribute from  BI_customer) d ON c.ccusheadcode=d.ccusheadcode
where 1=1 and c.cinvname_bi like '%1.71%'
"+if(and(or($fr_username ="21981",$fr_username ="14433"),len(propList)=0)," and cusattribute='电商客户'",if(len(propList)=0,""," and cusattribute in ('"+replace(propList,",","','")+"')"))+"
and ((convert(varchar(10),day_bi,23)>='"+stratDay+"'
and convert(varchar(10),day_bi,23)<='"+day+"') )
 GROUP BY b.market,c.ccusheadcode,b.prop_ywy,a.area_name,d.ccusname,d.ccusperson,d.cusAttribute,a.sarea_name
union all
select a.area_name,a.sarea_name,b.market,c.ccusheadcode,d.ccusname,d.cusAttribute,d.ccusperson,0 今年值,SUM(ISNULL(c.inatsum_bi,0)-isnull(c.thinatsum_bi,0))*b.prop_ywy AS 去年值,0 前年值,
  and ( (convert(varchar(10),day_bi,23)>='"+YEARDELTA(stratDay, -1)+"'
  and convert(varchar(10),day_bi,23)<='"+YEARDELTA(day, -1)+"'))
 union all
 select a.area_name,a.sarea_name,b.market,c.ccusheadcode,d.ccusname,d.cusAttribute,d.ccusperson,0 今年值,0 去年值,SUM(ISNULL(c.inatsum_bi,0)-isnull(c.thinatsum_bi,0))*b.prop_ywy AS 前年值,
  and ( (convert(varchar(10),day_bi,23)>='"+YEARDELTA(stratDay, -2)+"'
  and convert(varchar(10),day_bi,23)<='"+YEARDELTA(day, -2)+"')
 GROUP BY b.market,c.ccusheadcode,b.prop_ywy,a.area_name,d.ccusname,d.ccusperson,d.cusAttribute,a.sarea_name)
 aa   where 1=1
     "+if(len(saleList) == 0," and area_name in ( select distinct(sa.area_name) from BI_sale_area_part sa ,  BI_sale_userRole_new sb  where 1=1 and sb.userid='" +fr_username+ "'
 " +if(len(userMark) == 0," and  0 ",if(userMark==0," and 1 ",if(userMark==1," and sa.area_name ",if(userMark==2," and sa.sarea_name"," and sa.market "))))+ "= " +if(len(userMark) == 0,"   1 ",if(userMark==0,"  1 "," sb.area_name "))+ " )  "," and area_name in ('" + saleList + "')")+"
   "+if(len(qyList) == 0," and sarea_name in (select distinct(sa.sarea_name) from BI_sale_area_part sa ,  BI_sale_userRole_new sb  where 1=1 and sb.userid='" +fr_username+ "'
 " +if(len(userMark) == 0," and  0 ",if(userMark==0," and 1 ",if(userMark==1," and sa.area_name ",if(userMark==2," and sa.sarea_name"," and sa.market "))))+ "= " +if(len(userMark) == 0,"   1 ",if(userMark==0,"  1 "," sb.area_name "))+ ") "," and sarea_name in ('" + qyList + "')")+"
    "+if(len(scList) == 0," and market in (select distinct(sa.market) from BI_sale_area_part sa ,  BI_sale_userRole_new sb  where 1=1 and sb.userid='" +fr_username+ "'
 " +if(len(userMark) == 0," and  0 ",if(userMark==0," and 1 ",if(userMark==1," and sa.area_name ",if(userMark==2," and sa.sarea_name"," and sa.market "))))+ "= " +if(len(userMark) == 0,"   1 ",if(userMark==0,"  1 "," sb.area_name "))+ ") "," and market in ('" + scList + "')")+"
 group by area_name,sarea_name,market,ccusheadcode,ccusname,cusattribute,ccusperson,nameStr
 order by area_name,sarea_name,market,ccusheadcode
if(ywType="防蓝光","
select area_name,sarea_name,market,ccusheadcode,ccusname,cusattribute,ccusperson,sum(今年值) as 今年值,sum(去年值) as 去年值,sum(前年值) as  前年值 from
select  a.area_name,a.sarea_name,b.market,c.ccusheadcode,d.ccusname,d.cusAttribute,d.ccusperson,SUM(ISNULL(c.inatsum_bi,0))*b.prop_ywy AS 今年值,0 去年值,0 前年值,
  WHERE 1=1  and c.cinvname_bi like '%防蓝光%'
  and ( (convert(varchar(10),c.day_bi,23)>='"+stratDay+"'
  and convert(varchar(10),c.day_bi,23)<='"+day+"'))
 GROUP BY b.market,c.day_bi,c.ccusheadcode,c.year_bi,b.prop_ywy,a.area_name,d.ccusname,d.ccusperson,d.cusAttribute,a.sarea_name
 union all
 select  a.area_name,a.sarea_name,b.market,c.ccusheadcode,d.ccusname,d.cusAttribute,d.ccusperson,0 今年值,SUM(ISNULL(c.inatsum_bi,0))*b.prop_ywy AS 去年值,0 前年值,
  and ( (convert(varchar(10),c.day_bi,23)>='"+YEARDELTA(stratDay, -1)+"'
  and convert(varchar(10),c.day_bi,23)<='"+YEARDELTA(day, -1)+"'))
 union all
select  a.area_name,a.sarea_name,b.market,c.ccusheadcode,d.ccusname,d.cusAttribute,d.ccusperson,0 今年值,0 去年值,SUM(ISNULL(c.inatsum_bi,0))*b.prop_ywy AS 前年值,
  and ( (convert(varchar(10),c.day_bi,23)>='"+YEARDELTA(stratDay, -2)+"'
  and convert(varchar(10),c.day_bi,23)<='"+YEARDELTA(day, -2)+"'))
 )aa
 where 1=1
FineReport Q4512K41FF 发布于 2022-9-28 14:04 (编辑于 2022-9-28 14:05)
发布于2022-9-28 14:10
好长的SQL
建议改成
第一段sql if(ywType="1.71"," and 1=1"," and 1<>1")
union all
第二段SQL if(ywType="1.71"," and 1<>1"," and 1=1")
用户S5182147Lv6中级互助
发布于2022-9-28 14:14
 把测试的参数名称和对应的参数值也发一下
RiveryLv5中级互助
发布于2022-9-28 14:15(编辑于 2022-9-28 14:19)
只有第一个判断的数据是正确的,后面都是错误,这是啥意思?你填了防蓝光,输出的不是第二个执行语句吗
只有查询条件不一样的话 你可以只把查询条件放在${}里面呀,前面的查询不用判断的,因为是一样的
  • 370浏览人数
  • 最后回答于:2022-9-28 14:19
