怎么把夜里下班时间在凌晨3.30到7点的判断出来
SQL 数据分析菜鸡 发布于 2023-11-22 14:18
CovidLv3高级互助
发布于2023-11-22 14:31(编辑于 2023-11-22 17:06)
啥数据库:SqlServer?
with test as(
select '2016-03-16 09:09:48.383' [time_]
union all
select '2017-03-12 22:20:29.037'
union all
select '2016-03-14 21:52:16.160'
union all
select '2016-03-17 09:12:12.843'
union all
select '2016-03-17 09:10:12.843'
union all
union all
select '2016-03-17 08:12:12.843'
union all
select '2016-03-17 07:12:12.843'
union all
select '2016-03-17 15:24:00.070'
union all
union all
union all
select *,(CASE WHEN time_>=CONCAT(CONVERT(NVARCHAR(10),time_,120),' 20:30:00') AND time_<=CONCAT(CONVERT(NVARCHAR(10),DATEADD(DAY,1,time_),120),' 20:30:00') THEN '中班'
WHEN time_>=CONCAT(CONVERT(NVARCHAR(10),time_,120),' 03:30:00') AND time_<=CONCAT(CONVERT(NVARCHAR(10),time_,120),' 07:00:00') THEN '小夜班'
WHEN time_>=CONCAT(CONVERT(NVARCHAR(10),time_,120),' 07:00:00') AND time_<=CONCAT(CONVERT(NVARCHAR(10),time_,120),' 09:30:00') THEN '大夜'
 ELSE '未分类' END ) [TYPE_] from test
  • 223浏览人数
  • 最后回答于:2023-11-22 17:06
