数据查询参数问题
 我现在想根据fine_username 来判断是否属于这个区域的,例如fine_username=01 后面就是NL,fine_username=02就是NC
FineReport yzmBWKmn9966235 发布于 2023-11-23 13:56
CovidLv3高级互助
发布于2023-11-23 13:57(编辑于 2023-11-24 15:04)
SELECT * FROM TABLE WHERE 1=1 ${SWITCH(fine_username,"01"," AND XXX='NL',"02","AND XXX='NC'"")}
SELECT * FROM TABLE WHERE 1=1 ${SWITCH("true",find("NL",fine_username)>0," AND XXX='NL'",find("NC",fine_username)>0,"AND XXX='NC'")}
SELECT * FROM TABLE WHERE 1=1 ${SWITCH("true",find("NL",fine_username)>0," AND XXX='NL'",find("NC",fine_username)>0,"AND XXX='NC'",1=1," AND 1<>1")}
  • yzmBWKmn9966235 yzmBWKmn9966235(提问者) 那如果我的意思fine_username里面有nl的后面是 and xxx=\'NL\' 呢,就是不是一个确定的值 是一个包含nl的
    2023-11-23 14:02
  • Covid Covid 回复 yzmBWKmn9966235(提问者) 补充在上面了
    2023-11-23 14:05
  • Cloud777 Cloud777(提问者) 回复 Covid 那这个如果匹配不到的人 就无法访问数据 该怎么改呢
    2023-11-24 15:01
  • Covid Covid 回复 Cloud777(提问者) 补充在上面了
    2023-11-24 15:04
发布于2023-11-23 13:57(编辑于 2023-11-23 14:00)
${if(fine_username='01',"NL","Nc")}
你是要根据用户名查到区域代码?
select * from b
where 1=1
${if(sql("xxx","select code from b where user='"+fine_username+"',1,1")='01',"and xxx='NL'","and xxx='NC'")}
  • 199浏览人数
  • 最后回答于:2023-11-24 15:04
