数据库查询${if(or...和sql中的条件${if(len(参数)...如何一起使用,写法
${if(or(fine_username="1",fine_username="2",fine_username="3"),
"select  * from A
where 1=1
${if(len(参数1) == 0,"","and 字段1 in ('" + 字段1 + "')")}
${if(len(参数2) == 0,"","and 字段2 in ('" + 字段2 + "')")}  ",
"select * from B")}
FineReport yzmxAkXN2229786 发布于 2024-1-13 13:07
发布于2024-1-13 13:14(编辑于 2024-1-13 13:16)
${if(or(fine_username="1",fine_username="2",fine_username="3"),if(len(参数1) = 0,if(len(参数2) = 0,"","select  * from A where 字段2 in ('" + 字段2 + "')")),"select  * from A where 字段1 in ('" + 字段1 + "')","select * from B")}
  • 867浏览人数
  • 最后回答于:2024-1-13 13:16
