linux下用tomcat部署fr会挂了
2024/04/17 15:10:30 [SystemSupervisor-3-worker-1] ERROR FineOperation - get jmxConnector failed 2024/04/17 15:10:45 [SystemSupervisor-3-worker-1] INFO FineOperation - GcEventAnalyzer begin 2024/04/17 15:10:45 [SystemSupervisor-3-worker-1] ERROR FineOperation - java.lang.NoSuchMethodException: No similar method getAgentProperties with params [] could be found on type class java.lang.Object. com.fr.invoke.ReflectException: java.lang.NoSuchMethodException: No similar method getAgentProperties with params [] could be found on type class java.lang.Object. at com.fr.invoke.Reflect.call(Reflect.java:422) at com.fr.invoke.Reflect.call(Reflect.java:365) at com.fanruan.ops.subprocess.crash.server.core.help.AttachUtils.getJMXServiceURL(AttachUtils.java:59) at com.fanruan.ops.subprocess.crash.server.core.help.AttachUtils.getConnector(AttachUtils.java:44) at com.fanruan.ops.subprocess.crash.server.core.memory.GcEventAnalyzer.attachServer4Analysis(GcEventAnalyzer.java:94) at com.fanruan.ops.subprocess.crash.server.core.memory.GcEventAnalyzer.analysisGcInfo(GcEventAnalyzer.java:80) at com.fanruan.ops.subprocess.crash.server.core.memory.GcEventAnalyzer.isMemoryLoadHigh(GcEventAnalyzer.java:48) at com.fanruan.ops.subprocess.crash.server.core.process.FineProcessManager.analysisMemory(FineProcessManager.java:36) at com.fanruan.ops.subprocess.crash.server.core.process.SystemSupervisor.run(SystemSupervisor.java:59) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:748) Caused by: java.lang.NoSuchMethodException: No similar method getAgentProperties with params [] could be found on type class java.lang.Object. at com.fr.invoke.Reflect.similarMethod(Reflect.java:505) at com.fr.invoke.Reflect.call(Reflect.java:419) ... 15 more 2024/04/17 15:10:45 [SystemSupervisor-3-worker-1] ERROR FineOperation - get jmxConnector failed 2024/04/17 15:11:00 [SystemSupervisor-3-worker-1] INFO FineOperation - GcEventAnalyzer begin 2024/04/17 15:11:00 [SystemSupervisor-3-worker-1] ERROR FineOperation - java.lang.NoSuchMethodException: No similar method getAgentProperties with params [] could be found on type class java.lang.Object. com.fr.invoke.ReflectException: java.lang.NoSuchMethodException: No similar method getAgentProperties with params [] could be found on type class java.lang.Object. at com.fr.invoke.Reflect.call(Reflect.java:422) at com.fr.invoke.Reflect.call(Reflect.java:365) at com.fanruan.ops.subprocess.crash.server.core.help.AttachUtils.getJMXServiceURL(AttachUtils.java:59) at com.fanruan.ops.subprocess.crash.server.core.help.AttachUtils.getConnector(AttachUtils.java:44) at com.fanruan.ops.subprocess.crash.server.core.memory.GcEventAnalyzer.attachServer4Analysis(GcEventAnalyzer.java:94) at com.fanruan.ops.subprocess.crash.server.core.memory.GcEventAnalyzer.analysisGcInfo(GcEventAnalyzer.java:80) at com.fanruan.ops.subprocess.crash.server.core.memory.GcEventAnalyzer.isMemoryLoadHigh(GcEventAnalyzer.java:48) at com.fanruan.ops.subprocess.crash.server.core.process.FineProcessManager.analysisMemory(FineProcessManager.java:36) at com.fanruan.ops.subprocess.crash.server.core.process.SystemSupervisor.run(SystemSupervisor.java:59) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:748) Caused by: java.lang.NoSuchMethodException: No similar method getAgentProperties with params [] could be found on type class java.lang.Object. at com.fr.invoke.Reflect.similarMethod(Reflect.java:505) at com.fr.invoke.Reflect.call(Reflect.java:419) ... 15 more 2024/04/17 15:11:00 [SystemSupervisor-3-worker-1] ERROR FineOperation - get jmxConnector failed 2024/04/17 15:11:01 [SystemSupervisor-3-worker-1] INFO FineOperation - exit FineOperation 2024/04/17 15:11:01 [SystemSupervisor-3-worker-1] ERROR FineOperation - client kill server
FineReport lyyyy 发布于 2024-4-17 16:35
发布于2024-4-17 16:48
文档中只是说了大概
jdk你要安装好,同时要把jdk的环境变量在linux中配置好
linux配置jdk环境变量的三种方法_linux 配置jdk-CSDN博客
还有注意jdk的版本,也是有要求的你认真看文档
  • lyyyy lyyyy(提问者) 我配置了启动脚本 #!/bin/bash # 设置自定义的Tomcat实例名称 export TOMCAT_NAME=\"finereport-tomcat\" # 指定JDK路径 export JAVA_HOME=/home/jdk/jdk1.8.0_131 export PATH=$JAVA_HOME/bin:$PATH # 启Tomcat /home/finereport/finereport-tomcat9/bin/startup.sh 每次起了有一个小时可以用,过了一会就挂了
    2024-04-17 16:53
  • CD20160914 CD20160914 回复 lyyyy(提问者) 先不用自动启动脚本 。手动启动看,还有你的内存是多大?这个要8G起步。你要对决策系统设置最少8G的内存
    2024-04-17 16:57
  • lyyyy lyyyy(提问者) 回复 CD20160914 可用的还有4G可能是这个原因、
    2024-04-17 17:03
  • CD20160914 CD20160914 回复 lyyyy(提问者) 升级内存
    2024-04-17 17:05
  • yzmxYDx35608993 yzmxYDx35608993 回复 CD20160914 4g也能部署成
    2024-04-17 17:57
发布于2024-4-17 16:36(编辑于 2024-4-17 16:37)
  • lyyyy lyyyy(提问者) ...我也知道这几个文档啊,我是看不懂这个报错 这文档里也没有
    2024-04-17 16:39
  • 用户k6280494 用户k6280494 回复 lyyyy(提问者) 卸载干净,重新按文档部署,不要有遗漏
    2024-04-17 16:42
  • lyyyy lyyyy(提问者) 回复 用户k6280494 可我就是按这个部署的啊
    2024-04-17 16:43
fengjidlyLv2见习互助
发布于2025-5-19 13:42
您好,请问找到原因了吗?如何解决的呢?我是在 FineOperation日志找到了 kill server 的日志。
  • 338浏览人数
  • 最后回答于:2025-5-19 13:42
