数据集参数名称不能解析
-- 分片区
select
case when a.region_id='未知' then '未知'
       else a.salesregion_name end salesregion_name,
sum(a.total_follow_csm_qty) total_follow_csm_qty, -- 跟进消费者
sum(a.total_unfollow_csm_qty) total_unfollow_csm_qty, -- 未跟进消费者
sum(aa.inc_csm_qty) inc_csm_qty,
sum(a.total_core_csm_qty) total_core_csm_qty,
sum(aa.inc_core_csm_qty) inc_core_csm_qty,
sum(a.total_core_csm_mem_qty) total_core_csm_mem_qty,
sum(aa.inc_core_csm_mem_qty) inc_core_csm_mem_qty,
sum(a.total_active_core_csm_qty) total_active_core_csm_qty,
sum(d.active_consumer_qty) as active_core_csm_target,
sum(a.total_active_core_csm_qty)/sum(d.active_consumer_qty) as active_core_csm_target_ratio,
sum(fa.sunkol_qty) sunkol_qty,
sum(case when '${p_cmpy_code}' = '5137' then fa.tq_kol_qty else fa.kol_qty end) kol_qty,
sum(fa.moonkol_qty) moonkol_qty,
sum(fa.kolonsult_qty) kolonsult_qty,
sum(fa.starkol_qty) starkol_qty,
sum(fa.koc_qty) koc_qty,
sum(fa.poc_qty) poc_qty,
sum(b.mc_visit_times) as inc_visit_qty,
sum(b.mc_present_times) as inc_present_qty,
sum(c.act_times) as inc_mc_qty,
sum(c.act_fee_act) as inc_mc_amt,
sum(d.core_consumer_qty) as csm_124_target_qty,
round(sum(a.total_core_csm_qty)/sum(d.core_consumer_qty),4) csm_124_target_ratio
from (
-- 计算总数-已跟进消费者总数&未跟进消费者总数&核心消费者总数&核心消费者中会员覆盖数&活跃核心消费者数量(筛选结束时间之前的数据)
select
   IFNULL(cd.cms_region_id,'未知') as region_id,
   IFNULL(cd.cms_region_name,'未知') as region_name,
   IFNULL(cd.cms_area_id,'未知') as salesregion_id,
   IFNULL(cd.cms_area_name,'未知') as salesregion_name,
   count(distinct case when cd.is_follow=1 then cd.one_id else null end) total_follow_csm_qty,
   -- 已跟进消费者总数
   count(distinct case when cd.is_follow<>1 then cd.one_id else null end) total_unfollow_csm_qty,
   -- 未跟进消费者总数
   count(distinct case when cd.is_follow=1 and cd.is_core_consumer=1 then cd.one_id else null end) total_core_csm_qty,
   -- 核心消费者总数
   count(distinct case when cd.is_follow=1 and is_core_consumer=1 and cd.member_id is not null then cd.one_id else null end) total_core_csm_mem_qty,
   -- 核心消费者中会员覆盖数
   count(distinct case when cd.is_follow=1 and cd.is_core_consumer=1 then td.one_id else null end) total_active_core_csm_qty
       -- 活跃核心消费者数量
from dm_r_cm_csm_cmpy_consumer_detail as cd
-- 筛选有权限的数据
inner join (
-- 取只有公司权限数据
select
distinct
fa.company_code,
'1' as salesregion_id
from (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fa
left join (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fb
on fa.company_code=fb.company_code
union all
-- 取只有片区的权限数据
select
distinct
fa.company_code,
dco.l5_id as salesregion_id
from (select company_code,per_code  from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fa
left join (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fb
left join (select l5_id,l5_code from dim.dim_company_org group by l5_id,l5_code) as dco -- 获取片区的id
on fa.per_code=dco.l5_code
where fb.company_code is null
) as ta
on cd.company_code=ta.company_code
and case when ta.salesregion_id<>'1' then cd.cms_area_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end
-- 如果权限表里片区字段为1,表示拥有该公司下的所有权限;
-- 如果权限表里片区字段不为1,表示拥有该公司下某个片区的所有权限;
-- 原来的逻辑
-- left join (select * from dm_r_cm_csm_mc_ic_times_detail where business_year_id=(select max(business_year_id) from dm_r_cm_csm_mc_ic_times_detail))  as td -- 各财年触达次数
-- on cd.one_id=td.one_id   -- 本财年活跃核心消费者
--    and cd.cms_company_id=td.cms_company_id
-- 新的逻辑
left join [shuffle] (select one_id,cms_company_id
   group by one_id,cms_company_id
   having sum(mc_ic_times)>1 -- 触达次数大于1的数据为活跃消费者
   )  as td -- 各财年触达次数
where 1=1
  and cd.is_emp= 0 and cd.is_acct = 0 and cd.is_authentication=1
  and cd.company_cate_code = '${p_cmpy_code}'
      and cd.csm_create_date <= '${edate}'
${if(len(region_code)==0,"","AND cd.cms_region_name  = '"+ region_code +"'")}
${if(len(area_code)==0,"","AND cd.cms_area_name  = '"+ area_code +"'")}
group by IFNULL(cd.cms_region_id,'未知') ,
    IFNULL(cd.cms_region_name,'未知'),
    IFNULL(cd.cms_area_id,'未知'),
) as a
left join (
-- 新增消费者数量&新增核心消费者&核心消费者中新增会员覆盖数
select
   count(distinct case when cd.csm_create_date >= '${p_begin_day}' then cd.one_id else null end) inc_csm_qty,
   -- 新增消费者
   count(distinct case when cd.is_core_consumer=1 and cd.csm_create_date >= '${p_begin_day}' then cd.one_id else null end) inc_core_csm_qty,
   -- 新增核心消费者
       count(distinct case when is_core_consumer=1 and cd.csm_create_date >= '${p_begin_day}' and cd.member_id is not null then cd.one_id else null end) inc_core_csm_mem_qty
   -- 核心消费者中新增会员覆盖数
-- 筛选有权限的数据
inner join (
-- 取只有公司权限数据
select
distinct
fa.company_code,
union all
-- 取只有片区的权限数据
select
distinct
fa.company_code,
) as ta
where 1=1
  and cd.is_emp= 0 and cd.is_acct = 0 and cd.is_authentication=1 and cd.is_follow=1
) as aa
on a.region_id=aa.region_id and a.salesregion_id=aa.salesregion_id
left join (
-- 核心消费者分城市
select
   count(distinct case when sdk.k_type_query = 'SunKOL' then cd.one_id else null end) sunkol_qty,
       --太阳级KOL总数量
   count(distinct case when sdk.k_type_query like '%KOL%' then cd.one_id else null end) kol_qty,
       -- KOL总数
   count(distinct case when sdk.k_type_query = 'KOLGeneral' then cd.one_id else null end) tq_kol_qty,
   -- 特曲普通会员
   count(distinct case when sdk.k_type_query = 'KOLConsult' then cd.one_id else null end) kolonsult_qty,
   -- KOL 品牌顾问
   count(distinct case when sdk.k_type_query = 'MoonKOL' then cd.one_id else null end) moonkol_qty,
       -- 月亮级KOL总数量
   count(distinct case when sdk.k_type_query = 'StarKOL' then cd.one_id else null end) starkol_qty,
       -- 星星级KOL总数量
   count(distinct case when sdk.k_type_query = 'KOC' then cd.one_id else null end) koc_qty,
       --   KOC总数量
   count(distinct case when sdk.k_type_query = 'POC' then cd.one_id else null end) poc_qty
       -- POC总数量
-- 筛选有权限的数据
inner join (
-- 取只有公司权限数据
select
distinct
fa.company_code,
union all
-- 取只有片区的权限数据
select
distinct
fa.company_code,
) as ta
left join [shuffle] ( -- 获取筛选结束日期时的k_type类型,且取最新的一条
        select
        sd.consumer_id,
        sd.field_value as k_type_query,
        ROW_NUMBER() over(partition by consumer_id,create_date order by create_time desc) as rn_num
        from dim.dim_csm_track_scd as sd
        where sd.field_type='k_type'  -- 限制类型为k_type
        and sd.start_date <=  DATE_FORMAT('${edate}', '%Y%m%d')
        and ifnull(sd.end_date,"99991231")  >= DATE_FORMAT('${edate}', '%Y%m%d')  -- business_date为前端传过来的筛选时间的结束日期
        ) as sdk
        on sdk.rn_num=1 and cd.ma_consumer_id=sdk.consumer_id
where 1=1
  and cd.is_emp= 0 and cd.is_acct = 0 and cd.is_follow=1 and cd.is_authentication=1
group by  IFNULL(cd.cms_region_id,'未知'),
) as fa
on a.region_id=fa.region_id and a.salesregion_id=fa.salesregion_id
left join (
-- 消费者礼赠拜访指标(省份城市+销售公司)
  select
    IFNULL(cd.region_id,'未知') region_id,
    IFNULL(cd.salesregion_id,'未知') salesregion_id,
    sum(mc_visit_times) as mc_visit_times, -- 拜访人数
    sum(mc_present_times) as mc_present_times  -- 礼赠人数
  from dm_t_cm_csm_date_consumer as cd
  -- 筛选有权限的数据
inner join (
-- 取只有公司权限数据
select
distinct
fa.company_code,
union all
-- 取只有片区的权限数据
select
distinct
fa.company_code,
) as ta
and case when ta.salesregion_id<>'1' then cd.salesregion_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end
  where 1=1
  and company_cate_code = '${p_cmpy_code}'
  and business_date>='${p_begin_day}'
    ${if(len(region_code)==0,"","AND region_name  = '"+ region_code +"'")}
  ${if(len(area_code)==0,"","AND salesregion_name  = '"+ area_code +"'")}
  group by  IFNULL(cd.region_id,'未知'),
  having sum(mc_visit_times)>0 or sum(mc_present_times)>0
) as b on a.region_id=b.region_id and a.salesregion_id=b.salesregion_id
left join (
-- 活动场次和活动费用 --分城市
select
IFNULL(ct.region_id,'未知') region_id,
    IFNULL(ct.salesregion_id,'未知') salesregion_id,
sum(inc_act_qty) as act_times, -- 活动场次
sum(inc_act_fee_amt) as act_fee_act -- 活动费用
from dm_r_cm_csm_core_csm_target as ct -- 核心目标达成明细表
-- 筛选有权限的数据
inner join (
-- 取只有公司权限数据
select
distinct
fa.company_code,
union all
-- 取只有片区的权限数据
select
distinct
fa.company_code,
) as ta
on ct.company_code=ta.company_code
and case when ta.salesregion_id<>'1' then ct.salesregion_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end
inner join (select * from dim.man_dim_cmpy_cate where theme='consumer') dcc
on ct.cms_company_id=dcc.company_id
where 1=1
and dcc.company_cate_code = '${p_cmpy_code}'
and create_date>='${p_begin_day}'
group by IFNULL(ct.region_id,'未知'),
) as c on a.region_id=c.region_id and a.salesregion_id=c.salesregion_id
left join (
  -- 124目标人数指标(省份城市)
  select
    IFNULL(region_id,'未知') region_id,
    IFNULL(area_id,'未知') as salesregion_id,
    sum(core_consumer_qty) as core_consumer_qty, -- 目标核心消费者人数
    sum(ifnull(active_consumer_qty,0)) as active_consumer_qty  -- 目标活跃消费者人数
    from man_consumer_target
  where year_id = (select max(year_id) from man_consumer_target) -- 手工124目标取最新导入的那一年
    and cmpy_id = '${p_cmpy_code}'
  ${if(len(province_code)== 0,"","AND region_name = '" + region_code + "'")}
  ${if(len(city_code)== 0,"","AND area_name = '" + area_code + "'")}
  group by IFNULL(region_id,'未知'),
) as d on a.region_id=d.region_id and a.salesregion_id=d.salesregion_id
group by case when a.region_id='未知' then '未知'
having
sum(a.total_core_csm_qty)>0
order by
sum(a.total_core_csm_qty) desc;
FineReport 用户fAeNx5517943 发布于 2024-7-9 10:13 (编辑于 2024-7-9 10:27)
发布于2024-7-9 10:13(编辑于 2024-7-9 10:34)
刷新一下
刷新了也不出来参数 就把你上百行的SQL贴全
很多fine_username 用成了fine username,且把最后的分号删除
  • 用户fAeNx5517943 用户fAeNx5517943(提问者) 点了没用,预览sql能执行
    2024-07-09 10:19
  • Z4u3z1 Z4u3z1 回复 用户fAeNx5517943(提问者) 把SQL贴全 ,不要贴再回复里,这里面没法断句,注释都不知道到哪儿结束
    2024-07-09 10:21
  • 用户fAeNx5517943 用户fAeNx5517943(提问者) 回复 Z4u3z1 贴了
    2024-07-09 10:27
  • Z4u3z1 Z4u3z1 回复 用户fAeNx5517943(提问者) 很多fine_username 用成了fine username,且把最后的分号删除
    2024-07-09 10:35
  • 用户fAeNx5517943 用户fAeNx5517943(提问者) 回复 Z4u3z1 谢谢,可以了
    2024-07-09 16:04
发布于2024-7-9 10:14(编辑于 2024-7-9 10:46)
估计哪边拼接问题
全部sq贴出来,我们看看
select
sum(case when ${p_cmpy_code} = '5137' then fa.tq_kol_qty else fa.kol_qty end) kol_qty,
from (
select
inner join (
select
distinct
fa.company_code,
from (select company_code from dim.test_user_authority where user_code='${fine_username}' and granularity='公司') as fa
left join (select company_code,per_code from dim.test_user_authority where user_code='${fine_username}' and granularity='片区') as fb
union all
select
distinct
fa.company_code,
from (select company_code,per_code  from dim.test_user_authority where user_code='${fine_username}' and granularity='片区') as fa
left join (select company_code from dim.test_user_authority where user_code='${fine_username}' and granularity='公司') as fb
) as ta
   )  as td
where 1=1
) as a
left join (
select
inner join (
select
distinct
fa.company_code,
union all
select
distinct
fa.company_code,
) as ta
where 1=1
) as aa
left join (
select
inner join (
select
distinct
fa.company_code,
union all
select
distinct
fa.company_code,
) as ta
        select
       sd.consumer_id,
        ) as sdk
where 1=1
) as fa
left join (
  select
inner join (
select
distinct
fa.company_code,
union all
select
distinct
fa.company_code,
) as ta
  where 1=1
left join (
select
inner join (
select
distinct
fa.company_code,
union all
select
distinct
fa.company_code,
) as ta
where 1=1
left join (
  select
having
order by
效果
  • 用户fAeNx5517943 用户fAeNx5517943(提问者) -- 分片区 select case when a.region_id='未知' then '未知' else a.salesregion_name end salesregion_name, sum(a.total_follow_csm_qty) total_follow_csm_qty, -- 跟进消费者 sum(a.total_unfollow_csm_qty) total_unfollow_csm_qty, -- 未跟进消费者 sum(aa.inc_csm_qty) inc_csm_qty, sum(a.total_core_csm_qty) total_core_csm_qty, sum(aa.inc_core_csm_qty) inc_core_csm_qty, sum(a.total_core_csm_mem_qty) total_core_csm_mem_qty, sum(aa.inc_core_csm_mem_qty) inc_core_csm_mem_qty, sum(a.total_active_core_csm_qty) total_active_core_csm_qty, sum(d.active_consumer_qty) as active_core_csm_target, sum(a.total_active_core_csm_qty)/sum(d.active_consumer_qty) as active_core_csm_target_ratio, sum(fa.sunkol_qty) sunkol_qty, sum(case when '${p_cmpy_code}' = '5137' then fa.tq_kol_qty else fa.kol_qty end) kol_qty, sum(fa.moonkol_qty) moonkol_qty, sum(fa.kolonsult_qty) kolonsult_qty, sum(fa.starkol_qty) starkol_qty, sum(fa.koc_qty) koc_qty, sum(fa.poc_qty) poc_qty, sum(b.mc_visit_times) as inc_visit_qty, sum(b.mc_present_times) as inc_present_qty, sum(c.act_times) as inc_mc_qty, sum(c.act_fee_act) as inc_mc_amt, sum(d.core_consumer_qty) as csm_124_target_qty, round(sum(a.total_core_csm_qty)/sum(d.core_consumer_qty),4) csm_124_target_ratio from ( -- 计算总数-已跟进消费者总数&未跟进消费者总数&核心消费者总数&核心消费者中会员覆盖数&活跃核心消费者数量(筛选结束时间之前的数据) select IFNULL(cd.cms_region_id,'未知') as region_id, IFNULL(cd.cms_region_name,'未知') as region_name, IFNULL(cd.cms_area_id,'未知') as salesregion_id, IFNULL(cd.cms_area_name,'未知') as salesregion_name, count(distinct case when cd.is_follow=1 then cd.one_id else null end) total_follow_csm_qty, -- 已跟进消费者总数 count(distinct case when cd.is_follow<>1 then cd.one_id else null end) total_unfollow_csm_qty, -- 未跟进消费者总数 count(distinct case when cd.is_follow=1 and cd.is_core_consumer=1 then cd.one_id else null end) total_core_csm_qty, -- 核心消费者总数 count(distinct case when cd.is_follow=1 and is_core_consumer=1 and cd.member_id is not null then cd.one_id else null end) total_core_csm_mem_qty, -- 核心消费者中会员覆盖数 count(distinct case when cd.is_follow=1 and cd.is_core_consumer=1 then td.one_id else null end) total_active_core_csm_qty -- 活跃核心消费者数量 from dm_r_cm_csm_cmpy_consumer_detail as cd -- 筛选有权限的数据 inner join ( -- 取只有公司权限数据 select distinct fa.company_code, '1' as salesregion_id from (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fa left join (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fb on fa.company_code=fb.company_code union all -- 取只有片区的权限数据 select distinct fa.company_code, dco.l5_id as salesregion_id from (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fa left join (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fb on fa.company_code=fb.company_code left join (select l5_id,l5_code from dim.dim_company_org group by l5_id,l5_code) as dco -- 获取片区的id on fa.per_code=dco.l5_code where fb.company_code is null ) as ta on cd.company_code=ta.company_code and case when ta.salesregion_id<>'1' then cd.cms_area_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end -- 如果权限表里片区字段为1,表示拥有该公司下的所有权限; -- 如果权限表里片区字段不为1,表示拥有该公司下某个片区的所有权限; -- 原来的逻辑 -- left join (select * from dm_r_cm_csm_mc_ic_times_detail where business_year_id=(select max(business_year_id) from dm_r_cm_csm_mc_ic_times_detail)) as td -- 各财年触达次数 -- on cd.one_id=td.one_id -- 本财年活跃核心消费者 -- and cd.cms_company_id=td.cms_company_id -- 新的逻辑 left join [shuffle] (select one_id,cms_company_id from dm_r_cm_csm_mc_ic_times_detail where business_year_id=(select max(business_year_id) from dm_r_cm_csm_mc_ic_times_detail) group by one_id,cms_company_id having sum(mc_ic_times)>1 -- 触达次数大于1的数据为活跃消费者 ) as td -- 各财年触达次数 on cd.one_id=td.one_id -- 本财年活跃核心消费者 and cd.cms_company_id=td.cms_company_id where 1=1 and cd.is_emp= 0 and cd.is_acct = 0 and cd.is_authentication=1 and cd.company_cate_code = '${p_cmpy_code}' and cd.csm_create_date <= '${edate}' ${if(len(region_code)==0,"","AND cd.cms_region_name = '"+ region_code +"'")} ${if(len(area_code)==0,"","AND cd.cms_area_name = '"+ area_code +"'")} group by IFNULL(cd.cms_region_id,'未知') , IFNULL(cd.cms_region_name,'未知'), IFNULL(cd.cms_area_id,'未知'), IFNULL(cd.cms_area_name,'未知') ) as a left join ( -- 新增消费者数量&新增核心消费者&核心消费者中新增会员覆盖数 select IFNULL(cd.cms_region_id,'未知') as region_id, IFNULL(cd.cms_region_name,'未知') as region_name, IFNULL(cd.cms_area_id,'未知') as salesregion_id, IFNULL(cd.cms_area_name,'未知') as salesregion_name, count(distinct case when cd.csm_create_date >= '${p_begin_day}' then cd.one_id else null end) inc_csm_qty, -- 新增消费者 count(distinct case when cd.is_core_consumer=1 and cd.csm_create_date >= '${p_begin_day}' then cd.one_id else null end) inc_core_csm_qty, -- 新增核心消费者 count(distinct case when is_core_consumer=1 and cd.csm_create_date >= '${p_begin_day}' and cd.member_id is not null then cd.one_id else null end) inc_core_csm_mem_qty -- 核心消费者中新增会员覆盖数 from dm_r_cm_csm_cmpy_consumer_detail as cd -- 筛选有权限的数据 inner join ( -- 取只有公司权限数据 select distinct fa.company_code, '1' as salesregion_id from (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fa left join (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fb on fa.company_code=fb.company_code union all -- 取只有片区的权限数据 select distinct fa.company_code, dco.l5_id as salesregion_id from (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fa left join (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fb on fa.company_code=fb.company_code left join (select l5_id,l5_code from dim.dim_company_org group by l5_id,l5_code) as dco -- 获取片区的id on fa.per_code=dco.l5_code where fb.company_code is null ) as ta on cd.company_code=ta.company_code and case when ta.salesregion_id<>'1' then cd.cms_area_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end -- 如果权限表里片区字段为1,表示拥有该公司下的所有权限; -- 如果权限表里片区字段不为1,表示拥有该公司下某个片区的所有权限; where 1=1 and cd.is_emp= 0 and cd.is_acct = 0 and cd.is_authentication=1 and cd.is_follow=1 and cd.company_cate_code = '${p_cmpy_code}' and cd.csm_create_date <= '${edate}' ${if(len(region_code)==0,"","AND cd.cms_region_name = '"+ region_code +"'")} ${if(len(area_code)==0,"","AND cd.cms_area_name = '"+ area_code +"'")} group by IFNULL(cd.cms_region_id,'未知') , IFNULL(cd.cms_region_name,'未知'), IFNULL(cd.cms_area_id,'未知'), IFNULL(cd.cms_area_name,'未知') ) as aa on a.region_id=aa.region_id and a.salesregion_id=aa.salesregion_id left join ( -- 核心消费者分城市 select IFNULL(cd.cms_region_id,'未知') as region_id, IFNULL(cd.cms_region_name,'未知') as region_name, IFNULL(cd.cms_area_id,'未知') as salesregion_id, IFNULL(cd.cms_area_name,'未知') as salesregion_name, count(distinct case when sdk.k_type_query = 'SunKOL' then cd.one_id else null end) sunkol_qty, --太阳级KOL总数量 count(distinct case when sdk.k_type_query like '%KOL%' then cd.one_id else null end) kol_qty, -- KOL总数 count(distinct case when sdk.k_type_query = 'KOLGeneral' then cd.one_id else null end) tq_kol_qty, -- 特曲普通会员 count(distinct case when sdk.k_type_query = 'KOLConsult' then cd.one_id else null end) kolonsult_qty, -- KOL 品牌顾问 count(distinct case when sdk.k_type_query = 'MoonKOL' then cd.one_id else null end) moonkol_qty, -- 月亮级KOL总数量 count(distinct case when sdk.k_type_query = 'StarKOL' then cd.one_id else null end) starkol_qty, -- 星星级KOL总数量 count(distinct case when sdk.k_type_query = 'KOC' then cd.one_id else null end) koc_qty, -- KOC总数量 count(distinct case when sdk.k_type_query = 'POC' then cd.one_id else null end) poc_qty -- POC总数量 from dm_r_cm_csm_cmpy_consumer_detail as cd -- 筛选有权限的数据 inner join ( -- 取只有公司权限数据 select distinct fa.company_code, '1' as salesregion_id from (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fa left join (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fb on fa.company_code=fb.company_code union all -- 取只有片区的权限数据 select distinct fa.company_code, dco.l5_id as salesregion_id from (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fa left join (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fb on fa.company_code=fb.company_code left join (select l5_id,l5_code from dim.dim_company_org group by l5_id,l5_code) as dco -- 获取片区的id on fa.per_code=dco.l5_code where fb.company_code is null ) as ta on cd.company_code=ta.company_code and case when ta.salesregion_id<>'1' then cd.cms_area_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end -- 如果权限表里片区字段为1,表示拥有该公司下的所有权限; -- 如果权限表里片区字段不为1,表示拥有该公司下某个片区的所有权限; left join [shuffle] ( -- 获取筛选结束日期时的k_type类型,且取最新的一条 select sd.consumer_id, sd.field_value as k_type_query, ROW_NUMBER() over(partition by consumer_id,create_date order by create_time desc) as rn_num from dim.dim_csm_track_scd as sd where sd.field_type='k_type' -- 限制类型为k_type and sd.start_date = DATE_FORMAT('${edate}', '%Y%m%d') -- business_date为前端传过来的筛选时间的结束日期 ) as sdk on sdk.rn_num=1 and cd.ma_consumer_id=sdk.consumer_id where 1=1 and cd.is_emp= 0 and cd.is_acct = 0 and cd.is_follow=1 and cd.is_authentication=1 and cd.company_cate_code = '${p_cmpy_code}' and cd.csm_create_date <= '${edate}' ${if(len(region_code)==0,"","AND cd.cms_region_name = '"+ region_code +"'")} ${if(len(area_code)==0,"","AND cd.cms_area_name = '"+ area_code +"'")} group by IFNULL(cd.cms_region_id,'未知'), IFNULL(cd.cms_region_name,'未知'), IFNULL(cd.cms_area_id,'未知'), IFNULL(cd.cms_area_name,'未知') ) as fa on a.region_id=fa.region_id and a.salesregion_id=fa.salesregion_id left join ( -- 消费者礼赠拜访指标(省份城市+销售公司) select IFNULL(cd.region_id,'未知') region_id, IFNULL(cd.salesregion_id,'未知') salesregion_id, sum(mc_visit_times) as mc_visit_times, -- 拜访人数 sum(mc_present_times) as mc_present_times -- 礼赠人数 from dm_t_cm_csm_date_consumer as cd -- 筛选有权限的数据 inner join ( -- 取只有公司权限数据 select distinct fa.company_code, '1' as salesregion_id from (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fa left join (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fb on fa.company_code=fb.company_code union all -- 取只有片区的权限数据 select distinct fa.company_code, dco.l5_id as salesregion_id from (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fa left join (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fb on fa.company_code=fb.company_code left join (select l5_id,l5_code from dim.dim_company_org group by l5_id,l5_code) as dco -- 获取片区的id on fa.per_code=dco.l5_code where fb.company_code is null ) as ta on cd.company_code=ta.company_code and case when ta.salesregion_id<>'1' then cd.salesregion_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end -- 如果权限表里片区字段为1,表示拥有该公司下的所有权限; -- 如果权限表里片区字段不为1,表示拥有该公司下某个片区的所有权限; where 1=1 and company_cate_code = '${p_cmpy_code}' and business_date>='${p_begin_day}' ${if(len(region_code)==0,"","AND region_name = '"+ region_code +"'")} ${if(len(area_code)==0,"","AND salesregion_name = '"+ area_code +"'")} group by IFNULL(cd.region_id,'未知'), IFNULL(cd.salesregion_id,'未知') having sum(mc_visit_times)>0 or sum(mc_present_times)>0 ) as b on a.region_id=b.region_id and a.salesregion_id=b.salesregion_id left join ( -- 活动场次和活动费用 --分城市 select IFNULL(ct.region_id,'未知') region_id, IFNULL(ct.salesregion_id,'未知') salesregion_id, sum(inc_act_qty) as act_times, -- 活动场次 sum(inc_act_fee_amt) as act_fee_act -- 活动费用 from dm_r_cm_csm_core_csm_target as ct -- 核心目标达成明细表 -- 筛选有权限的数据 inner join ( -- 取只有公司权限数据 select distinct fa.company_code, '1' as salesregion_id from (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fa left join (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fb on fa.company_code=fb.company_code union all -- 取只有片区的权限数据 select distinct fa.company_code, dco.l5_id as salesregion_id from (select company_code,per_code from dim.test_user_authority where user_code='${fine username}' and granularity='片区') as fa left join (select company_code from dim.test_user_authority where user_code='${fine username}' and granularity='公司') as fb on fa.company_code=fb.company_code left join (select l5_id,l5_code from dim.dim_company_org group by l5_id,l5_code) as dco -- 获取片区的id on fa.per_code=dco.l5_code where fb.company_code is null ) as ta on ct.company_code=ta.company_code and case when ta.salesregion_id<>'1' then ct.salesregion_id else 1 end = case when ta.salesregion_id<>'1' then ta.salesregion_id else 2 end -- 如果权限表里片区字段为1,表示拥有该公司下的所有权限; -- 如果权限表里片区字段不为1,表示拥有该公司下某个片区的所有权限; inner join (select * from dim.man_dim_cmpy_cate where theme='consumer') dcc on ct.cms_company_id=dcc.company_id where 1=1 and dcc.company_cate_code = '${p_cmpy_code}' and create_date>='${p_begin_day}' ${if(len(region_code)==0,"","AND region_name = '"+ region_code +"'")} ${if(len(area_code)==0,"","AND salesregion_name = '"+ area_code +"'")} group by IFNULL(ct.region_id,'未知'), IFNULL(ct.salesregion_id,'未知') ) as c on a.region_id=c.region_id and a.salesregion_id=c.salesregion_id left join ( -- 124目标人数指标(省份城市) select IFNULL(region_id,'未知') region_id, IFNULL(area_id,'未知') as salesregion_id, sum(core_consumer_qty) as core_consumer_qty, -- 目标核心消费者人数 sum(ifnull(active_consumer_qty,0)) as active_consumer_qty -- 目标活跃消费者人数 from man_consumer_target where year_id = (select max(year_id) from man_consumer_target) -- 手工124目标取最新导入的那一年 and cmpy_id = '${p_cmpy_code}' ${if(len(province_code)== 0,"","AND region_name = '" + region_code + "'")} ${if(len(city_code)== 0,"","AND area_name = '" + area_code + "'")} group by IFNULL(region_id,'未知'), IFNULL(area_id,'未知') ) as d on a.region_id=d.region_id and a.salesregion_id=d.salesregion_id group by case when a.region_id='未知' then '未知' else a.salesregion_name end having sum(a.total_core_csm_qty)>0 order by sum(a.total_core_csm_qty) desc;
    2024-07-09 10:19
  • snrtuemc snrtuemc 回复 用户fAeNx5517943(提问者) 好长,这个所有注释去掉,最后;去掉,这些sql数据集不支持的
    2024-07-09 10:28
  • 用户fAeNx5517943 用户fAeNx5517943(提问者) 回复 snrtuemc 注释前面都没影响,这次只是增加了一些权限
    2024-07-09 10:37
  • snrtuemc snrtuemc 回复 用户fAeNx5517943(提问者) 我给你改好了,最主要是第一个参数那边,是字段,不要引号,看修改答案
    2024-07-09 10:45
  • 142浏览人数
  • 最后回答于:2024-7-9 10:46
