分组汇总后刷新报错,为什么每次需要更改列名才可以
保存之后显示更新失败,只有第一次excel上传数据的时候显示更新成功
FineBI 帆软用户592xGqdvND 发布于 2024-7-31 18:59 (编辑于 2024-8-1 18:16)
luojian0323Lv7资深互助
发布于2024-7-31 19:07
这个要看日志,具体什么报错呀?
  • 帆软用户592xGqdvND 帆软用户592xGqdvND(提问者) java.lang.RuntimeException: INTERNAL: blockPipeline init failed detail message is : The folder:[{}] not exist [/home/fineBI/webapps/webroot/bi-data/polars/spider_cache/journal] stackTrace is : java.lang.IllegalArgumentException: The folder:[{}] not exist [/home/fineBI/webapps/webroot/bi-data/polars/spider_cache/journal] at com.fanruan.polars.report.common.base.Preconditions.checkArgument(Preconditions.java:217) at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.(BinaryItemFileAppender.java:66) at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.(BinaryItemFileAppender.java:83) at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.create(BinaryItemFileAppender.java:141) at com.fanruan.polars.tools.store.BinaryItemFileAppenderHelper.create(BinaryItemFileAppenderHelper.java:82) at com.fanruan.polars.core.component.SimpleCommonServiceManager.getPlanNodeRecorder(SimpleCommonServiceManager.java:798) at com.fanruan.polars.core.component.SimpleCommonServiceManager.lambda$initExecutionManager$6(SimpleCommonServiceManager.java:636) at com.fanruan.polars.execution.SimpleRocketFactory.record(SimpleRocketFactory.java:59) at com.fanruan.polars.execution.SimpleRocketFactory.submit(SimpleRocketFactory.java:72) at com.fanruan.polars.execution.SimpleExecutionManager$TaskEater.run(SimpleExecutionManager.java:136) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:750) at com.fanruan.polars.grpc.server.StreamObserverWithErrorStackTrace.getExceptionWithStackTrace(StreamObserverWithErrorStackTrace.java:13) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.grpc.server.SubThreadStreamObserver.onErrorSubThreadWithStackTrace(SubThreadStreamObserver.java:20) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.server.worker.QueryWithSourceBlockStreamObserver$AsyncJob.lambda$asyncInitJobAndReply$2(QueryWithSourceBlockStreamObserver.java:126) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.server.worker.SimpleWorkerAsyncExecutor.lambda$runQuery$4(SimpleWorkerAsyncExecutor.java:212) ~[fine-bi-engine-third-6.0.jar:?] at org.apache.skywalking.apm.toolkit.trace.CallableWrapper.call(CallableWrapper.java:37) ~[fine-third-11.0.jar:?] at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_392] at java.lang.Thread.run(Thread.java:750) ~[?:1.8.0_392]
    2024-08-01 09:47
  • 帆软用户592xGqdvND 帆软用户592xGqdvND(提问者) 你好,一直报的是这个问题,第一次操作没问题,刷新就会报出这个问题
    2024-08-01 09:47
  • luojian0323 luojian0323 回复 帆软用户592xGqdvND(提问者) 用的什么数据集? 除了看到管道初始化失败,没看到其他有用信息。 这是全部日志吗?
    2024-08-02 10:20
  • 帆软用户592xGqdvND 帆软用户592xGqdvND(提问者) 回复 luojian0323 java.lang.RuntimeException: blockPipeline init failed detail message is : The folder:[{}] not exist [/home/fineBI/webapps/webroot/bi-data/polars/spider_cache/journal] stackTrace is : java.lang.IllegalArgumentException: The folder:[{}] not exist [/home/fineBI/webapps/webroot/bi-data/polars/spider_cache/journal] at com.fanruan.polars.report.common.base.Preconditions.checkArgument(Preconditions.java:217) at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.(BinaryItemFileAppender.java:66) at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.(BinaryItemFileAppender.java:83) at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.create(BinaryItemFileAppender.java:141) at com.fanruan.polars.tools.store.BinaryItemFileAppenderHelper.create(BinaryItemFileAppenderHelper.java:82) at com.fanruan.polars.core.component.SimpleCommonServiceManager.getPlanNodeRecorder(SimpleCommonServiceManager.java:798) at com.fanruan.polars.core.component.SimpleCommonServiceManager.lambda$initExecutionManager$6(SimpleCommonServiceManager.java:636) at com.fanruan.polars.execution.SimpleRocketFactory.record(SimpleRocketFactory.java:59) at com.fanruan.polars.execution.SimpleRocketFactory.submit(SimpleRocketFactory.java:72) at com.fanruan.polars.execution.SimpleExecutionManager$TaskEater.run(SimpleExecutionManager.java:136) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:750) at com.fanruan.polars.grpc.server.StreamObserverWithErrorStackTrace.getExceptionWithStackTrace(StreamObserverWithErrorStackTrace.java:13) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.grpc.server.SubThreadStreamObserver.onErrorSubThreadWithStackTrace(SubThreadStreamObserver.java:20) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.server.worker.QueryWithSourceBlockStreamObserver$AsyncJob.lambda$asyncInitJobAndReply$2(QueryWithSourceBlockStreamObserver.java:126) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.server.worker.SimpleWorkerAsyncExecutor.lambda$runQuery$4(SimpleWorkerAsyncExecutor.java:212) ~[fine-bi-engine-third-6.0.jar:?] at org.apache.skywalking.apm.toolkit.trace.CallableWrapper.call(CallableWrapper.java:37) ~[fine-third-11.0.jar:?] at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_392] at java.lang.Thread.run(Thread.java:750) ~[?:1.8.0_392] 18:04:06 ERROR [polars-task-eater-8-thread-29] [log]Rocket factory submit task:192.168.0.11-polars-1902 got error java.lang.IllegalArgumentException: The folder:[{}] not exist [/home/fineBI/webapps/webroot/bi-data/polars/spider_cache/journal] at com.fanruan.polars.report.common.base.Preconditions.checkArgument(Preconditions.java:217) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.(BinaryItemFileAppender.java:66) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.(BinaryItemFileAppender.java:83) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.spi.data.tools.BinaryItemFileAppender.create(BinaryItemFileAppender.java:141) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.tools.store.BinaryItemFileAppenderHelper.create(BinaryItemFileAppenderHelper.java:82) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.core.component.SimpleCommonServiceManager.getPlanNodeRecorder(SimpleCommonServiceManager.java:798) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.core.component.SimpleCommonServiceManager.lambda$initExecutionManager$6(SimpleCommonServiceManager.java:636) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.execution.SimpleRocketFactory.record(SimpleRocketFactory.java:59) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.execution.SimpleRocketFactory.submit(SimpleRocketFactory.java:72) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.execution.SimpleExecutionManager$TaskEater.run(SimpleExecutionManager.java:136) ~[fine-bi-engine-third-6.0.jar:?] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_392] at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_392] at java.lang.Thread.run(Thread.java:750) ~[?:1.8.0_392] 18:04:06 ERROR [polars-task-eater-8-thread-29] Print task:[192.168.0.11-polars-1902] got error java.util.NoSuchElementException: No value present at java.util.Optional.get(Optional.java:135) ~[?:1.8.0_392] at com.fanruan.polars.execution.SimpleExecutionManager.lambda$genMetricPrinter$2(SimpleExecutionManager.java:69) ~[fine-bi-engine-third-6.0.jar:?] at com.fanruan.polars.execution.SimpleExecutionManager$TaskEater.run(SimpleExecutionManager.java:138) ~[fine-bi-engine-third-6.0.jar:?] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_392] at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_392] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_392] at java.lang.Thread.run(Thread.java:750) ~[?:1.8.0_392]
    2024-08-02 18:27
  • 帆软用户592xGqdvND 帆软用户592xGqdvND(提问者) 回复 luojian0323 就是这个错误一直在重复打印
    2024-08-02 18:27
JL98Lv6中级互助
发布于2024-8-1 10:08
你再分组上面加一个步骤 字段设置,列名在 字段设置 里设置后再分组汇总,试一下呢
  • 帆软用户592xGqdvND 帆软用户592xGqdvND(提问者) 还是不行,还是要一直换名称才可以,保存之后显示刷新失败
    2024-08-01 18:10
  • JL98 JL98 回复 帆软用户592xGqdvND(提问者) 再按这个步骤做一个看一下呢
    2024-08-02 08:35
  • 帆软用户592xGqdvND 帆软用户592xGqdvND(提问者) 回复 JL98 试了好几遍,都需要换个名字才可以,保存之后就显示更新失败
    2024-08-02 18:29
  • 216浏览人数
  • 最后回答于:2024-8-1 18:16
