数据集的sql语句
SELECT
    CASE
        WHEN '${timeScale}' = '年' THEN TO_CHAR(TO_TIMESTAMP(alert.ALARM_TIME, 'YYYYMMDDHH24MISS'), 'YYYY')
        WHEN '${timeScale}' = '季' THEN TO_CHAR(TO_TIMESTAMP(alert.ALARM_TIME, 'YYYYMMDDHH24MISS'), 'YYYY') || 'Q' || TO_CHAR(TO_TIMESTAMP(alert.ALARM_TIME, 'YYYYMMDDHH24MISS'), 'Q')
        WHEN '${timeScale}' = '月' THEN TO_CHAR(TO_TIMESTAMP(alert.ALARM_TIME, 'YYYYMMDDHH24MISS'), 'YYYY-MM')
        WHEN '${timeScale}' = '周' THEN TO_CHAR(TO_TIMESTAMP(alert.ALARM_TIME, 'YYYYMMDDHH24MISS'), 'IYYY-IW')
        WHEN '${timeScale}' = '日' THEN TO_CHAR(TO_TIMESTAMP(alert.ALARM_TIME, 'YYYYMMDDHH24MISS'), 'YYYY-MM-DD')
    END AS time_group,
    alert.*
FROM NED_Straight_through_alert alert
WHERE
    TO_TIMESTAMP(alert.ALARM_TIME, 'YYYYMMDDHH24MISS') BETWEEN
    CASE
        WHEN '${timeRange}' = '自定义' THEN TO_TIMESTAMP(TO_CHAR('${startDate}', 'YYYYMMDD') || '000000', 'YYYYMMDDHH24MISS')
        WHEN '${timeRange}' = '本年' THEN TRUNC(SYSDATE, 'YYYY')
        WHEN '${timeRange}' = '本季' THEN TRUNC(SYSDATE, 'Q')
        WHEN '${timeRange}' = '本月' THEN TRUNC(SYSDATE, 'MM')
        WHEN '${timeRange}' = '本周' THEN TRUNC(SYSDATE, 'IW')
        WHEN '${timeRange}' = '昨日' THEN TRUNC(SYSDATE - 1)
        WHEN '${timeRange}' = '今日' THEN TRUNC(SYSDATE)
    END
    AND
    CASE
        WHEN '${timeRange}' = '自定义' THEN TO_TIMESTAMP(TO_CHAR('${endDate}', 'YYYYMMDD') || '235959', 'YYYYMMDDHH24MISS')
        WHEN '${timeRange}' = '本年' THEN ADD_MONTHS(TRUNC(SYSDATE, 'YYYY'), 12) - INTERVAL '1' SECOND
        WHEN '${timeRange}' = '本季' THEN ADD_MONTHS(TRUNC(SYSDATE, 'Q'), 3) - INTERVAL '1' SECOND
        WHEN '${timeRange}' = '本月' THEN ADD_MONTHS(TRUNC(SYSDATE, 'MM'), 1) - INTERVAL '1' SECOND
        WHEN '${timeRange}' = '本周' THEN TRUNC(SYSDATE, 'IW') + 7 - INTERVAL '1' SECOND
        WHEN '${timeRange}' = '昨日' THEN TRUNC(SYSDATE) - INTERVAL '1' SECOND
        WHEN '${timeRange}' = '今日' THEN TRUNC(SYSDATE) + INTERVAL '1' DAY - INTERVAL '1' SECOND
    END
    AND alert.model = '${model}'
    AND alert.lot = '${lot}'
    AND alert.linename = '${lineno}'
ORDER BY time_group DESC只要是自定义的,查询的时候就没有数据,选本年,本月这些就没问题
FineReport 帆软用户ewz4VgkDjz 发布于 2024-8-15 16:39
CovidLv3高级互助
发布于2024-8-15 16:42
这没有自定义情况
  • 帆软用户ewz4VgkDjz 帆软用户ewz4VgkDjz(提问者) 这个是那个别的参数,用来控制一个图的横坐标的刻度的,也需要改么?
    2024-08-15 17:12
  • Covid Covid 回复 帆软用户ewz4VgkDjz(提问者) 不好意思参数名看错了。你把日志级别改成debug后再预览,然后去日志提取带参后的SQL看看
    2024-08-15 17:19
发布于2024-8-15 16:42
把参数填入默认值,fr11可以预览sql,在sql工具里调试一下
  • 140浏览人数
  • 最后回答于:2024-8-15 16:42
