如何把2.5转换成2天12小时
如何把2.5转换成2天12小时
FineReport yzm101920 发布于 2024-11-25 13:29 (编辑于 2024-11-25 13:29)
发布于2024-11-25 13:29(编辑于 2024-11-25 13:39)
什么规律
2小时30分钟吧?
优化下
IF(int(2.5)>=1,CONCATENATE(int(2.5),"天",(2.5-int(2.5))*24,"小时"),CONCATENATE(2.5*24,"小时"))
  • yzm101920 yzm101920(提问者) 2.5就是2天12小时,0.75就是18小时,这种的
    2024-11-25 13:32
  • snrtuemc snrtuemc 回复 yzm101920(提问者) 那就是 CONCATENATE(int(2.5),"天",(2.5-int(2.5))*24,"小时") 看修改答案
    2024-11-25 13:36
发布于2024-11-25 13:34(编辑于 2024-11-25 13:40)
INDEXOFARRAY(SPLIT(REPLACE("2.5",".",","),","),1)+"天"+ ("0."+INDEXOFARRAY(SPLIT(REPLACE("2.5",".",","),","),2)) * 24 +"小时"
发布于2024-11-25 13:50
INT(a6)+"天"+(a6-int(a6))*24+"小时"
  • 145浏览人数
  • 最后回答于:2024-11-25 13:50
