${IF(参数,语句1,语句2)},字段不同,只能出来一个语句的字段
FineReport Clown. 发布于 2024-12-3 10:43
发布于2024-12-3 10:43(编辑于 2024-12-3 10:44)
参数名,改成你的控件的名称才可以
PS
改成
${if(控件名="true","sql1","sql2")}
  • Clown. Clown.(提问者) 不是,是只能出来一个语句的字段,看左侧
    2024-12-03 10:44
  • snrtuemc snrtuemc 回复 Clown.(提问者) 这个对的啊,只有你给参数了,他才会动态出现另一个语句字段,目前应该是出现第二个语句的字段,第一个不会,
    2024-12-03 10:46
  • Clown. Clown.(提问者) 改了,只是没贴图,我想到一个方法,两条ds?可行? ${if(控件名="true","sql1")} ${if(控件名="false","sql2")}
    2024-12-03 10:48
  • snrtuemc snrtuemc 回复 Clown.(提问者) 那就分两个数据集,写,第一个,${if(控件名="true","sql1","select 1")} 第二个数据集 ${if(控件名="false","sql2","select 1")} 这样还是两个数据集,一个数据集是不行的
    2024-12-03 10:51
  • Clown. Clown.(提问者) 回复 snrtuemc 请问,如果想在语句里加 ${if(len(物料编码) == 0,"","and c.FNumber = '"+ 物料编码 + "'")} 这个怎么加,我刚刚加了 参数就剩一个 物料编码了
    2024-12-03 11:04
Zzz1002Lv2见习互助
发布于2024-12-3 10:53
with a as (select 1 as column1,2 as column2 from dual),
b as (select 1 as column1,2 as column2,3 as column3 from dual),
c as (select 1 as column1,2 as column2,3 as column3,4 as column4 from dual)
select
a.column1,a.column2,b.column3
${if(detail='True',"",",sum(c.column4)")}
from a
left join b on a.column1=b.column1 and a.column2=b.column2
${if(detail='True',"","left join c on a.column1=c.column1 and a.column2=c.column2")}
where 1=1
${if(detail='True',"","group by a.column1,a.column2,b.column3")}
${if(detail='True',"order by a.column1,a.column2,b.column3","")}
  • 96浏览人数
  • 最后回答于:2024-12-3 10:53
