在sql语句中如何使用模板参数的值?
我设置了一个模板参数,使用value()函数获取数据集的值,然后我在另一个数据集中使用
${if(len(dept)==0,"and did in (模板参数)"," and did in ("+"'"+treelayer(dept, true, "\',\'")+"'"+")")}来判断dept是否为空,如果为空,就取模板参数的值,请问"and did in (模板参数)"应该如何实现呢
FineReport 用户e2379142 发布于 2025-3-5 15:33
发布于2025-3-5 15:39
${if(len(dept)==0,"and did in ('"+replace(orgs,",","','")+"')"," and did in ("+"'"+treelayer(dept, true, "\',\'")+"'"+")")}
发布于2025-3-5 15:34
${if(len(dept)==0,"and did in ('"+模板参数名称+"')"," and did in ("+"'"+treelayer(dept, true, "\',\'")+"'"+")")}
  • 27浏览人数
  • 最后回答于:2025-3-5 15:39
