请问怎么通过是否配置角色来控制sql查询条件
请问怎么通过是否配置角色来控制 sql查询条件, 请问我的语句该怎么调
-- 有配置角色 看对应团队数据
${if(len(fine_role) == 0,"
and exists (select 1
from dw_crm.dws_crm_finereport_role t1
join (select distinct t.vc_fundcode, t.vc_cust_mngrid, t.vc_objeno,
t.vc_effectivedate as vc_bgndate, t.vc_enddate,
t1.vc_ori_dept_crm as c_nodecode
from dw.dw_empl_cust_brok_rela t
    join dw.dw_empl_main_dept_crm t1
on (t.vc_cust_mngrid = t1.vc_emplno_crm and t.vc_effectivedate <= t1.vc_enddate and t.vc_enddate >= t1.vc_bgndate)
where t.vc_audit_status = '0' -- 审核通过
and t.vc_obje_type = '1' -- 客户
-- and t.vc_cust_mngrid = (select distinct vc_emplid_crm from dw.dw_empl_base_info_crm where vc_email = '${p_email}')
) t2
on (t1.fr_role_name in ('${REPLACE(fine_role,",","','")}')
and t2.c_nodecode like t1.c_nodevalue||'%'
where t2.vc_fundcode = a1.vc_fundcode
and t2.vc_objeno = a1.vc_custno
and a1.vc_cdate >= t2.vc_bgndate
and a1.vc_cdate <= t2.vc_enddate
-- 无配置角色-看自己的数据
and exists (
select 1
from (select distinct t.vc_fundcode, t.vc_cust_mngrid, t.vc_objeno,
) t2
FineReport Y5266752 发布于 2025-5-20 17:05
发布于2025-5-20 17:06(编辑于 2025-5-20 17:10)
根据账号控制查询数据权限
select * from table where 1=1
${if(find('角色A',fine_role)>0,"and xxx","and xxx")}
find('角色A',fine_role)>0含有角色A
yzm665590Lv3见习互助
发布于2025-5-20 17:54(编辑于 2025-5-20 18:02)
我之前用的是笨办法,select * from ( select *,(全部)角色字段  from 表A    union all    select *, (自身)角色字段  from 表A)a
where 1=1
${if(len(fine_role) == 0,角色字段="全部",角色字段="自身")}
  • 28浏览人数
  • 最后回答于:2025-5-20 18:02
