外面包了一层${}的时候,里面的为空查全部怎么写呢
${if(len(date)==0,
"   select * from  data
    if(len(data)==0,"","and data in ('"+data+"')")
FineReport yzm529517 发布于 2025-8-28 14:24
发布于2025-8-28 14:28
${if(len(date)==0,
" select * from  data"
    +if(len(data)==0,"","and data in ('"+data+"')")
  • yzm529517 yzm529517(提问者) 不能 if(len(data)==0,"","and data in ('"+data+"')")直接改这块吗我现在是获取不到data参数了
    2025-08-28 14:35
发布于2025-8-28 14:30(编辑于 2025-8-28 14:36)
直接这样呗
select * from  data
WHERE
    ${if(len(data)==0,"and data in ('"+data+"')","1=2")}
简单除暴的写法
${if(rq<today(),"/*","")}
SQL1部分
${if(rq<today(),"*/","")}
${if(rq>=today(),"/*","")}
SQL2部分
${if(rq>=today(),"*/","")}
  • yzm529517 yzm529517(提问者) 不行啊我最外层有if判断根据if不同执行不同的sql
    2025-08-28 14:33
  • 华莉星宸 华莉星宸 回复 yzm529517(提问者) 给你个简单除暴的写法
    2025-08-28 14:36
发布于2025-8-28 14:36
${if(len(date)==0,if(len(data)==0,"select * from  data","select * from  data where data in ('"+data+"')")
  • 51浏览人数
  • 最后回答于:2025-8-28 14:36
