SQL该怎么写
t_type_day.sql
t_type_mon.sql
笔试题.docx
Latty 发布于 2020-12-7 12:02 (编辑于 2020-12-7 12:59)
AmyQLv6初级互助
发布于2020-12-7 12:27(编辑于 2020-12-7 13:08)
1、
Select name,sum(case when Type_nm='交易金额' then day_val end)/ sum(case when Type_nm='交易笔数' then day_val end) avg_val  from  t_type_day group by NAME
2、
Select name from(
       Select name,sum(val) val from(
         Select name,`mon_val(当月累计值)` val from  t_type_mon where Type_nm='交易金额'
           Union all
         Select name,day_val val from  t_type_day where Type_nm='交易金额')A group by name)A1
    Order by val desc limit 1
3、
Select name,val1 from(
       Select name, sum(case when Type_nm='交易金额' then day_val end) val1,
               sum(case when Type_nm='交易笔数' then day_val end) val2  from  t_type_day group by name)A
     Where val2>100 order by val1  desc
  • 344浏览人数
  • 最后回答于:2020-12-7 13:08
