如何在数据集里写IF语句
求帮忙看下哪里错了
${IF(统计条件="OUT","SELECT DISTINCT A.ITEMSPEC,A.ITEMID,A.ITEMNAME,C.UNITSNAME,SUM(D.UNITSQUANTITY) UNITSQUANTITY,SUM(D.ROUNDREALAMOUNT) ROUNDREALAMOUNT
FROM NEWAY_HIS_HNXX_1210.NBDITEMMAIN A
INNER JOIN NEWAY_HIS_HNXX_1210.NBDITEMMEDPROPERTY B ON A.ITEMID=B.ITEMID
INNER JOIN NEWAY_HIS_HNXX_1210.NBDITEMUNITS C ON B.ITEMID=C.ITEMID  AND C.UNITSTYPEID='0401'
INNER JOIN NEWAY_HIS_HNXX_1210.NOP0501B D ON C.ITEMID = D.ITEMID AND C.UNITSSERIAL=D.UNITSSERIAL
INNER JOIN NEWAY_HIS_HNXX_1210.NOP0501A E ON D.SETTLEID = E.SETTLEID
WHERE A.ITEMTYPEID LIKE '01%' AND B.ESSENTIALDRUGTYPEID ='01' AND D.UNITSQUANTITY>0 AND E.SETTLEDATETIME>=TO_DATE('"+开始日期+"','yyyy-mm-dd hh24:mi:ss') AND E.SETTLEDATETIME<TO_DATE('"+结束日期+"','yyyy-mm-dd hh24:mi:ss')
GROUP BY A.ITEMSPEC,A.ITEMID,A.ITEMNAME,C.UNITSNAME",IF(统计条件="IN","SELECT DISTINCT A.ITEMSPEC,A.ITEMID,A.ITEMNAME,C.UNITSNAME,SUM(D.UNITSQUANTITY) UNITSQUANTITY,SUM(D.ROUNDREALAMOUNT) ROUNDREALAMOUNT
INNER JOIN NEWAY_HIS_HNXX_1210.NIP0601B D ON C.ITEMID = D.ITEMID AND C.UNITSSERIAL=D.UNITSSERIAL
INNER JOIN NEWAY_HIS_HNXX_1210.NIP0601A E ON d.CHARGEID = E.CHARGEID
WHERE A.ITEMTYPEID LIKE '01%' AND B.ESSENTIALDRUGTYPEID ='01' AND D.UNITSQUANTITY>0 AND E.CHARGEDATETIME>=TO_DATE('"+开始日期+"','yyyy-mm-dd hh24:mi:ss') AND E.CHARGEDATETIME<TO_DATE('"+结束日期+"','yyyy-mm-dd hh24:mi:ss')
GROUP BY A.ITEMSPEC,A.ITEMID,A.ITEMNAME,C.UNITSNAME",IF(统计条件="ALL","SELECT DISTINCT A.ITEMSPEC,A.ITEMID,A.ITEMNAME,C.UNITSNAME,SUM(D.UNITSQUANTITY) UNITSQUANTITY,SUM(D.ROUNDREALAMOUNT) ROUNDREALAMOUNT
UNION ALL
GROUP BY A.ITEMSPEC,A.ITEMID,A.ITEMNAME,C.UNITSNAME","")))}
FineReport Zod1ac 发布于 2021-1-5 10:14 (编辑于 2021-1-5 11:41)
fangqingLv5初级互助
发布于2021-1-5 11:32(编辑于 2021-1-5 13:57)
${if(控件="门诊","SELECT * FROM A WHERE 时间大于开始日期小于结束日期",if(控件="住院","SELECT * FROM B WHERE 时间大于开始日期小于结束日期","SELECT * FROM C WHERE 时间大于开始日期小于结束日期"))};
${IF(统计条件='OUT',
IF(统计条件='IN',
IF(统计条件='ALL',
UNION ALL
demo1Lv6见习互助
发布于2021-1-5 10:17
${if(条件,"select * from a","select * from b")}
  • Zod1ac Zod1ac(提问者) 前面不需要写SELECT吗。。。那我怎么把数据填进单元格
    2021-01-05 10:19
  • demo1 demo1 回复 Zod1ac(提问者) 前面有if判断,看执行哪一段sql语句
    2021-01-05 10:21
  • Zod1ac Zod1ac(提问者) 回复 demo1 那三段条件怎么写呢
    2021-01-05 10:26
luojian0323Lv7资深互助
发布于2021-1-5 10:18
你要先告诉我你的逻辑
${if(时间参数="值1","select 门诊 from 表",if(时间参数='值2',"select 住院 from 表",if(时间参数="值3","select 全部字段 from 表","")))}
  • Zod1ac Zod1ac(提问者) 是${if(控件=\'门诊\',\"SELECT * FROM A WHERE 时间大于开始日期小于结束日期\",\"SELECT * FROM B WHERE 时间大于开始日期小于结束日期\")}这样
    2021-01-05 10:22
  • luojian0323 luojian0323 回复 Zod1ac(提问者) 那不就是这样吗? 把我上面语句改一改就好了。
    2021-01-05 10:26
huxiaolongLv4见习互助
发布于2021-1-5 14:16(编辑于 2021-1-5 14:26)
用帆软if函数判断条件在确定sql,语句看起来比较复杂。从给的内容看应该是条件=in,一个sql1,条件=out则是,sql2,条件all的话是 sql1 union all sql2。那么可以把if写到sql里,如下:
AND E.SETTLEDATETIME>=TO_DATE('${开始日期}','yyyy-mm-dd hh24:mi:ss')
AND E.SETTLEDATETIME<TO_DATE('${结束日期}','yyyy-mm-dd hh24:mi:ss')
${if(统计条件 in ('OUT', 'ALL'), "and 1=1", "and 0=1")}
UNION ALL
AND E.CHARGEDATETIME>=TO_DATE('${开始日期}','yyyy-mm-dd hh24:mi:ss')
AND E.CHARGEDATETIME<TO_DATE('${结束日期}','yyyy-mm-dd hh24:mi:ss')
${if(统计条件 in ('IN', 'ALL'), "and 1=1", "and 0=1")}
这样看起来简洁些。
  • Zod1ac Zod1ac(提问者) 鹅。。。报错了
    2021-01-05 14:22
  • huxiaolong huxiaolong 回复 Zod1ac(提问者) union all 下面个0=1 前面忘加and了
    2021-01-05 14:25
  • Zod1ac Zod1ac(提问者) 回复 huxiaolong 还是报错。。。。帆软对多统计途径太不友好了吧。。。
    2021-01-05 14:33
  • huxiaolong huxiaolong 回复 Zod1ac(提问者) 看着没什么问题呀,不知道报的什么错
    2021-01-05 15:56
  • 573浏览人数
  • 最后回答于:2021-1-5 14:26
