根据下拉参数是否为空,判断sql查询哪些字段。这个是否能实现。
select substr(MODIFY_TIME,1,4) year,substr(MODIFY_TIME,6,2) month,
if '$(月份)' is null then
substr(MODIFY_TIME,6,2) day
else
substr(MODIFY_TIME,9,2) day
end if,
sum(STHYSHSL),sum(NSDYSHSL),sum(BSDYSHSL),sum(JGHYSHSL),sum(XSDYSHSL),
from ***
where substr(MODIFY_TIME,1,4) = '${年份}'
${if(len(月份) == 0,"","and substr(MODIFY_TIME,6,2) = '" + 月份 + "'")}
group by substr(MODIFY_TIME,6,2),substr(MODIFY_TIME,1,4),substr(MODIFY_TIME,9,2)
order by substr(MODIFY_TIME,1,4)
报错:
FineReport 快乐程序员 发布于 2021-5-25 16:34
烟尘Lv6高级互助
发布于2021-5-25 16:37(编辑于 2021-5-25 16:44)
${if(len(月份) == 0," substr(MODIFY_TIME,6,2) day, "," substr(MODIFY_TIME,9,2) day, ")}
from ***
发布于2021-5-25 16:38
改成下面
${if(len(月份) == 0,"substr(MODIFY_TIME,6,2) day","substr(MODIFY_TIME,9,2) day")},
from ***
SrafyLv5见习互助
发布于2021-5-25 16:41
from前面  , ……
  • 438浏览人数
  • 最后回答于:2021-5-25 16:44
