直接CC列写下面公式
if(replace(AA,"%","")>100,2-BB/replace(AA,"%",""),if(replace(AA,"%","")<100,BB/replace(AA,"%",""),replace(AA,"%","")))
那就参考上判断,用replace函数把%去掉,就可以当数值使用了,只要用到AA,就用replace(AA,"%","")代替
,还有个方案,就是AA原值,然后做辅助列,假设AA1,直接写replace(AA,"%",""),然后后面计算判断都用AA1来代替,隐藏AA1
