祈LLv6中级互助发布于2021-9-10 17:06(编辑于 2021-9-10 17:06)
或是||,图中&&是和
用户sBHcR0905332(提问者)
- $.data.[?( @.date>=${begintime} && @.date<=${endtime})] 这种形式参数只能用一个用两个会报错不知道为什么
祈L 回复 用户sBHcR0905332(提问者)
- 参数看类型,字符串加单引号\'${begintime}\'
用户sBHcR0905332(提问者) 回复 祈L
- 不是这个类型的原因,因为只使用一个参数的时候是没问题的
$.data.[?( @.date>=${begintime} )] 这样是没有问题的,但是有两个参数就会报错
报错信息:[?]can not be applied to primitives
- 你这个应该是数据问题吧,截图看一下你的json数据
- {\"code\":200,\"message\":\"success\",\"data\":[{\"date\":20210730,\"value\":272.49},{\"date\":20210731,\"value\":277.1},{\"date\":20210801,\"value\":293.62},{\"date\":20210802,\"value\":293.27},{\"date\":20210803,\"value\":284.42},{\"date\":20210804,\"value\":284.7},{\"date\":20210805,\"value\":281.02},{\"date\":20210806,\"value\":241.82},{\"date\":20210807,\"value\":279.48},{\"date\":20210808,\"value\":282.3},{\"date\":20210809,\"value\":294.29},{\"date\":20210810,\"value\":270.47},{\"date\":20210811,\"value\":278.41},{\"date\":20210812,\"value\":292.84},{\"date\":20210813,\"value\":295.86},{\"date\":20210814,\"value\":283.1},{\"date\":20210815,\"value\":286.22},{\"date\":20210816,\"value\":295.73},{\"date\":20210817,\"value\":273.28},{\"date\":20210818,\"value\":289.39},{\"date\":20210819,\"value\":276.77},{\"date\":20210820,\"value\":266.63},{\"date\":20210821,\"value\":270.01},{\"date\":20210822,\"value\":275.17},{\"date\":20210823,\"value\":274.92},{\"date\":20210824,\"value\":264.35},{\"date\":20210825,\"value\":255.86},{\"date\":20210826,\"value\":266.33},{\"date\":20210827,\"value\":276.99},{\"date\":20210828,\"value\":269.61},{\"date\":20210829,\"value\":265.0},{\"date\":20210830,\"value\":261.02}]} 大概就是这种形式
